Whats up! Got a little situation here. Just installed a clutch masters stage 3 Kevlar clutch in the del sol. Immediately after installing and bleeding the clutch it felt supper spongy! Way softer than stock!!! Went through 3 bottles of brake fluid with no change. Only have to push pedal down about a inch to shift! After driving a little over 100 miles like that I felt a vibration followed by knocking. Sounded just like rod knock actually! So I parked it. Oil pressure good. Checked fluids. All good there... Let it sit over night. Start it the next morning. Same rod knock sound. Forced it in reverse to pull out the garage and the knock got real bad with bad vibration in the clutch pedal. Go to put it in first and it wont go into gear at all. Pedal stays to the floor! Now and the clutch is stuck engaged! Still knocking. Sound is coming from the bell housing area no doubt! Clutch pedal is dead and if I force it into first it will actually start to pull forward! Put it in first with clutch pedal to the ground and try to start it and it jumps! Any input?... Ever heard of this?... Thanks guys!
Jun 22, 2008 at 10:36 PM
