1994 Honda Del Sol Honda starts, idles rough, dies on accel
1994 HONDA DEL SOL
160,000 MILES • 4 CYL • 2WD • MANUAL
YAZRO
If this car had a carburetor, I'd say the passing/acceleration passages were clogged.
It starts, idles rough (as if the choke is not working) would die if the pedal is not tickled, idles better warm and will not move forward unless the pedal is pumped to get revs up. Absolutely no power.
These symptoms have to point to a very specific part of the Fuel Injection system, No?
Sep 15, 2009 at 10:24 AM
KHLOW2008
  • 41,814 POSTS
Hi yazro,
Possible causes for the problem are:
1. Unequal compression. Valve clearances might need adjustment. Get a compression done if all others checks out ok.
2. Faulty Throttle Position Sensor.
3. Low fuel pressure.
4. Bad spark plugs, wires, distributor cap, rotor, ignition coil.
5. Valve timing out of sync. Was timing belt replaced?
Is the Check engine light showing?
Was anything done prior to this happening?
Sep 15, 2009 at 1:23 PM
YAZRO
I agree this would be a last resort since I parked one day and a few days later the problem occured.
That could be the problem. I got 5V for the baseline but I could not get a reading with my Voltmeter with the engine running so will try that again.
Possible but when I took the cap off and turned the key on. fuel spurted out 6" in the air so there is some pressure.
I did recently replace the coil when it died on me while driving, but cap, rotor, plugs and wires does not seem to fit the profile.
Don't know the history of the belt but again seems unlikely given the suddeness of the issue, which would indicte more of an electrical/electronic issue.
Is the Check engine light showing? Check engine light goes out as it should. No codes when jumpered.
Was anything done prior to this happening? - just the coil.
You are leaning to the throttle position sensor as opposed to any other fi sensor? Like O2 sensor or MAP? Thanks for your help...
Sep 15, 2009 at 2:32 PM
KHLOW2008
  • 41,814 POSTS
Sorry if I missed this out. You mentioned it starts idling rough when cold. That should not be the case as the fast idle valve should be operating and the idling speed should be at more than 1000 rpm.
If this is the case, the most likely problem is engine compression. Check tha valve clearance, tight valve clearance would cause such problem.
If you have coolant depleting and/or overheating issues, you might have a bad head gasket.
Sep 16, 2009 at 10:35 AM
