1993 Honda Del Sol Idling really high
1993 HONDA DEL SOL
230,000 MILES • 4 CYL • 2WD • MANUAL
KRAYZEEPINOI
Hey i ran over a puddle of water in my delsol doesnt have the cover under the car so you can see right to the ground when you look into the engine, Im guessing it sucked up some water and now the engine idles high for 5 minutes straight at 3000 rpms in neutral gear. Sometimes if i leave it in neutral gear and rev it high then it goes back down to normal idle but once i start pushing the gears back up to 3000+ rpms it starts staying around 3000-4000 rpms. Anyway I can fix this problem?
Dec 19, 2009 at 11:04 PM
Clean the idle air control valve and test the throttle position sensor.
Dec 20, 2009 at 6:03 AM
