honda D15B 2004 breather hose connection
2003 HONDA CIVIC
98,000 MILES • 1.5L • 4 CYL • FWD • AUTOMATIC
SHAMIUL HASAN
  • 8 POSTS
at the back my honda civic Exi D15B 2004 engine breather have 2 hose pointers, please let me know from where it is get connect.
Mar 29, 2016 at 12:33 AM
SATURNTECH9
  • 30,869 POSTS
Can you take a picture where your talking about.Also are you talking about the pcv that's inserted in the valve cover?
Mar 30, 2016 at 7:38 PM
SHAMIUL HASAN
  • 8 POSTS
Please see the picture and the Question mark. I hope you can understand now.
Mar 30, 2016 at 10:18 PM
SATURNTECH9
  • 30,869 POSTS
So the bottom nipple you have with the question mark is that blocked off inside the nipple or hallow?because sometimes they change things and just block off nipples from the factory I stead of not putting them on anymore.Also is this a USA model car?
Mar 30, 2016 at 11:19 PM
SHAMIUL HASAN
  • 8 POSTS
No actually my Question is in that diagram you see that one hoes is connected to the first nipple. but I want to know from where the hoes is get connect on to the second nipple.
Mar 30, 2016 at 11:25 PM
SHAMIUL HASAN
  • 8 POSTS
my car is Right hand drive mode, not USA model, Asia model.
Mar 30, 2016 at 11:27 PM
SATURNTECH9
  • 30,869 POSTS
The bottom larger nipple on the intake manifold?I was asking is that nipple hollow or is open?Also that's the one your trying to hook up?
Mar 31, 2016 at 6:38 AM
SATURNTECH9
  • 30,869 POSTS
Also it's a 1.5L engine for sure?The problem is we only have access to USA model cars repair information like vacuum diagrams etc.
Mar 31, 2016 at 6:49 AM
SHAMIUL HASAN
  • 8 POSTS
I don't know actually. But did not have any problem on that while I drive. But curious to know that from where that get connect if that was get opens and sorry for the miss communication. However please think in fresh mind to not solve any problem just star the knowledge ?
Mar 31, 2016 at 6:54 AM
SHAMIUL HASAN
  • 8 POSTS
Sorry for the keyboard problem Star= Share.????
Mar 31, 2016 at 6:56 AM
SATURNTECH9
  • 30,869 POSTS
Look at the nipple and see if it's open or filled in?if it's filled in nothing gets hooked to it.
Mar 31, 2016 at 7:58 AM
SATURNTECH9
  • 30,869 POSTS
There's a lack of understanding on that last sentence you posted?I was asked by my boss to answer this question.If you were trying to say don't answer a question I don't have direct knowledge.If I miss under your meaning I apologize.If the nipple is sealed off there wouldn't be s hose going to it.Also if I knew for sure if it was a 1.5L engine I could try to find a vacuum diagram.For the USA models it doesn't list a 1.5L engine.
Mar 31, 2016 at 12:12 PM
SHAMIUL HASAN
  • 8 POSTS
Ok I'm answering you the next nipple hoes comes from the master cylinder air hoes. Which is connected with the manifold second nipple and the upper nipple come from the valve which is right beside the throttle body. Thank you for your time.
Mar 31, 2016 at 9:46 PM
SATURNTECH9
  • 30,869 POSTS
Did you ever look and see if the nipple with no hose is hollow or open?that's what I keep asking you and still haven't gotten answer yet.Also if I knew for sure what size engine you had that would really make it a lot easier to try to help you.
Mar 31, 2016 at 9:57 PM
SHAMIUL HASAN
  • 8 POSTS
Thank you for your reply but answering more should be.1. If blovked=the reason for block. If no= from where it should be connected. In the other way when I have told that wheather the engine should be is that D15b or D15y3 what ever are almost same just it might 1.7 L or 1.5 L. Requesting you try to understand always is the question is problem solving or knowledge sharing.
Mar 31, 2016 at 10:06 PM
SATURNTECH9
  • 30,869 POSTS
If it's blocked off I told you the manufacturer did that as a design change and there never was a hose going it.If it's blocked your question is answered there is no hose going to it.Also without the correct engine size I can't going searching for a vacuum diagram.So please answer if it's blocked office it is question answered.If it isn't need the correct engine size?So when I get those we can move on with this question.
Mar 31, 2016 at 10:27 PM
