my crx revs up and down between 900rpm and 2300rpm , thought this was the map sensor , changed it twice and no difference . but when you dissconect the vacume pipe from the map sensor , or the manifoild end the car will idle perfect . but will only run for about 20 second s then the engine check light comes on and the car stops running . need help :(
Aug 15, 2006 at 2:18 PM
