Fuel Leak
HONDA CRX
KMONTGOMERY
86 CRX si / 340000km / 1.5litre
I have a fuel leak apparantly where the gas tank joins the fuel line, a mechanic told me that the "coupler" had rusted and that's where the leak was coming from. I can't find the part to replace it anywhere. Is this the right name for the part? Is there a diagram online anywhere for the fuel delivery system with part numbers etc listed?
Oct 6, 2007 at 2:38 PM
JAY6647
  • 17 POSTS
I'm assuming your refering to the fuel tank "neck" that is rusted. The "neck" is actually part of the fuel tank itself. You would be better off replacing the whole fuel tank (part # 17500SB2684) which cost about $350 from the dealer. Rust does not occur in one spot only, it's probally already rusted inside the fuel tank. Labor to replace the tank should not be more then 2 hours. Hope this helps. Good luck!!!
Oct 6, 2007 at 3:15 PM
KMONTGOMERY
I'm assuming your refering to the fuel tank "neck" that is rusted. The "neck" is actually part of the fuel tank itself. You would be better off replacing the whole fuel tank (part # 17500SB2684) which cost about $350 from the dealer. Rust does not occur in one spot only, it's probally already rusted inside the fuel tank. Labor to replace the tank should not be more then 2 hours. Hope this helps. Good luck!!![/quote:acad7c5adc]
When you buy a new tank does it normally come with the part (couple) to connect the neck to the fuel line?
Oct 6, 2007 at 7:54 PM
HUMBLEGUMBO
  • 7 POSTS
purchase from a parts site, but at least you'll have a better understanding of what's included in the assembly, how things go together, & a ballpark price on parts.
The CRX fuel tank is surprisingly easy to remove & replace. If you have a safe way of jacking up the car, some basic tools, & a container to store the fuel you could easily do this yourself. If you're intimidated, get the chilton/haynes manual. It shows how to do this step by step.
Oct 20, 2007 at 4:57 PM
