Engine turns over, and has spark, main relay OK, distributor OK, fuel pump sounds, each time, injectors pulse, do not smell gas, checked fuses in engine compartment and under dash, will fire with starting fluid but quits a second later. . . what next? Anything else?if I need to check fuel pump pressure how do I that simply as I do not want to pull the tank . ANY SUGGESTIONS
Apr 9, 2009 at 9:54 AM
