1991 HONDA CRX DX WITH DUAL POINT INJECTION 5SP MANUAL
1991 HONDA CRX
HONDASENCE76
CAR WONT START. In field 1 1/2 years. Replace (all new) fuel tank,pump,injectors,fuel filter,pressure relief valve,plugs wires,distributor(rebuilt),intake,exhaust headers, o2 sensor,main relay,ecu (computer).
Pump runs and has fuel, gets fuel to injectors, ijectors get power, ECU dosnt blink codes, if pour gas in throttle body... runs.
Gas comes into injectors with pressure. vac lines look good.
Answer if you can! no one else can.
Nov 17, 2007 at 1:34 PM
ETBOB
Other people say it is the "main relay". Either take it apart and resolder internal components or get a new one or one from a junkyard.
Jul 12, 2008 at 10:16 PM
DANIEL-CRX
  • 7 POSTS
check your timing because it could be off.
Feb 25, 2009 at 2:13 PM
BUTLLIT0985
sounds to me like your not getting gas into the motor. think about it u replaced all of it and it still dont run unless u put gas in the throttle and runs for a few minutes then that means one thing your not getting gass into the motor from the injectors somethings not right with it check the injectors again see if there pluged. thats what it sounds like to me
Aug 12, 2010 at 1:37 PM
