1991 Honda CRX car want stay on
1991 HONDA CRX
MONTIERICKO
1991 Honda CRX si 4 cyl mileage: 3[img:7adbacee77]http://www.2carpros.com/forum/automotive_pictures/281064_60951603uu8zn1_1.jpg[/img:7adbacee77][img:7adbacee77]http://www.2carpros.com/forum/automotive_pictures/281064_14672593zp1vu7_1.jpg[/img:7adbacee77]
16,000 Two Wheel Drive Manual
ok i was drivein my crx and everythig was good then i came to a light to make a right hand turn the car just cutt off on me.the only way it will stay on if i hold the key turn as soon as i let it go it cutts right back off what can this be is this the IGNITION SWITCH or the Ignition Lock Assembly please help me ?????
Dec 3, 2008 at 8:19 PM
DAVE H
  • 13,384 POSTS
the contact's may be worn in the ignition switch .. when you turn key does it feel any different .. ie. looses/spinning .. IGNITION SWITCH NOTE:The ignition switch is the electrical contact portion of ignition lock cylinder only. Removal & Installation Turn ignition off. Remove instrument panel lower trim panel and lower steering column covers. Disconnect 4-pin connector from dash fuse block and 5-pin connector from main wiring harness. See Fig. 8 . Insert ignition key into lock cylinder and turn cylinder to "0" position. Remove 2 retaining screws and pull ignition switch from ignition lock body. See Fig. 11 . To install, reverse removal procedure. Fig. 11: Removing Ignition Switch Courtesy of AMERICAN HONDA MOTOR CO., INC.
https://www.2carpros.com/forum/automotive_pictures/266999_iggy_2.jpg
Dec 3, 2008 at 8:45 PM
MONTIERICKO
thanks alot bro = )
Dec 3, 2008 at 8:53 PM
