1990 Honda CRX Radiator cooling fan rigged
1990 HONDA CRX
160,000 MILES • 4 CYL • 2WD • MANUAL
DUSTINT
So i just bought a crx and someone has totally butcherd the wiring horribly, its a nightmare, well anyway the fan is rigged up to a toggle switch theres two positive wires coming off the fans and theres a negative going onto the battery. Is there anyway I could fix it back to normal because its annoying to have to turn it on and off.[img:c81636db0f]http://www.2carpros.com/forum/automotive_pictures/190895_1rrr_1.jpg[/img:c81636db0f]
May 16, 2008 at 9:22 AM
KHLOW2008
  • 41,814 POSTS
Check and see if looping the thermosensor wire socket operates the fan. If it works, change the switch.
May 28, 2008 at 10:00 AM
