1990 Honda CRX High revving at deceleration
1990 HONDA CRX
GEONRACER
Noises problem
1990 Honda CRX 4 cyl Front Wheel Drive Manual
I have a 1990 crx i was driving home tonight and i shifted to thrird gear and then i all of a sudden when i nuetral dropped it at the light my engine was revving high i then engaged the clutch to proceed and the clutch seemed to be working but it was a little sluggish and when i put it in nuetral it sounded like the engine was revving high well it was it was staying around 2grand whats the deal? i know it cant be the clutch and i dont race the car?
Jul 1, 2010 at 11:42 PM
KHLOW2008
  • 41,814 POSTS
Hi geonracer,
When stopped and in neutral, the revving should not be from the clutch but rather the idle control.
Check the throttle bnody for foreign materials lodged in between the plates.
Check the throttle cable for sticking.
Check for leaking vacumns.
Is the Check Engine Light indicating?
Jul 2, 2010 at 1:54 PM
GEONRACER
No the check engine light is not on i dont know if the guy before me took out the light? Ii saw the throttle cable and it looked like it was loose.
Jul 3, 2010 at 11:36 AM
KHLOW2008
  • 41,814 POSTS
Turn ignitnon switch on and the CEL should come on for 2 seconds and then turn off.
You need the CEL to be operating to check for codes.
Did you check for vacumn leakages?
Jul 3, 2010 at 10:48 PM
