1987 Honda CRX help me plz
1987 HONDA CRX
C.SHAFFER83
Engine Mechanical problem
1987 Honda CRX 4 cyl Front Wheel Drive Manual
ok here is my ? well i have a 87crx with a 87 integra motor swap and the car ran before i got it and ive been working on it for the longest now and the car would stat but stal out as soon as it started and found out some wires waz burnt in the distributor and going to replace is but i waz wondering about what elsa i could cheak around for and the location i could be looking for to check the car gets gas and everything the main relay works fine does its 3 clicks and all i friend of mind told me to look around the vacum lines but i dont know what all i would be looking for or what to look for on the vacum lines i know all the vacum lines are working i think lol but any help you be great its my only car for right know so with it being down it is makeing things hard on me so someone plz help
Oct 17, 2008 at 4:36 AM
KHLOW2008
  • 41,814 POSTS
Hi c.shaffer83,
We should go a step at a time. Get the distributor problem solved and see if the engine runs well.
For your model if there is any vacumn leaks, the idling rpm would surge so I don't think there is any problem with that since you mentioned it stalls after starting.
It should be more of the cold start or idling system problem. Clean the throttle body with carb cleaner and don't forget to remove the idle adjust screw and spary some cleaner into it as well.
Oct 17, 2008 at 2:08 PM
