1987 Honda CRX Brake bleeding
1987 HONDA CRX
210,000 MILES • 4 CYL • FWD • MANUAL
XCORPS89
I replaced my rear shoes and hardware, adjusted the E brake, and bled my brakes. However, i forgot to leave the master cylinder cap off and while I bleeding the system I saw that I leaking fluid aourd the the booster/cylinder area. I checked all around and can't find where the fluid is coming from. So I continued to bleed the system with the cylinder cap "off" this time.
I got good pedal pressure and saw air coming out of the lines. But during the drive test I no pressure, ZERO!! I have no leaks anywhere. No air coming out of lines.
Did I damage my booster and/or cylinder when I bled the system with the master cylinder cap on??
Aug 9, 2009 at 11:01 AM
KHLOW2008
  • 41,814 POSTS
Hi xcorps89,
Either there is still air in the system or the master cylinder is bad. Quite often master cylinders that are weak fails when bleeding is done.
I would suggest testing the master cylinder.
Aug 9, 2009 at 2:07 PM
