I have a honda crx, zc1 with pgmfi, 1.6 16v... problem with cooling the engine > when i drive the car under 2000rpm, everything works fine, but when i drive a little faster, the engine cooling is not working well.. and after few miles the throtle is going up and down between 1000 and 2500 rpm.. I stoped the engine, wait till its cooled (must wait becouse ther is a huge pressure in radiator), i turn on the engine, get of the radiator cap, and then, slowley, bubbles are coming up.. when all bubbles are out, i put a coolant water back that is missing, and than everything is ok again, till I not drive faster than 2000rpm.. the termostat, radiator cap and the head gasket are changed, and there is no oli in water, just pressure and bubbles...what could be the problem?
Feb 11, 2009 at 12:49 PM
