This question is about a 1984 Honda CRX 1.3 5 speed. I changed the head gasket and rebuilt the carb. When I try start it, it just turns(cranks) but no starting. I looked at the "First Things To Check". I put gas in the carb, checked for spark (which looked kinda weak) and double checked the timing. The engine turns as if the timing is off. Does it make a difference if it is the exhaust or intake cycle as long as it lines up with the dist. #1 plug? the only thing left to check would be valve clearance or ignition coil resistance. Is this right or what should I do?
Sep 21, 2010 at 11:28 AM
