1984 Honda CRX internal fuel leak on carburator
1984 HONDA CRX
SAMMMMMMMM
Engine Performance problem
1984 Honda CRX 4 cyl Front Wheel Drive Manual
My 84 honda leaks in the secondary I replaced the needle and seat and the level in the sight glass is good. then I replaced the 2 oring gaskets on the plate and it still leaks is there something else that I can replace to get it to stop leaking?
Oct 17, 2008 at 12:31 PM
KHLOW2008
  • 41,814 POSTS
Hi sammmmmmmm,
When the secondary venturi os leaking, you should check if the throttle valve is completely closed. When the linkages are stuck, it would leave a gap for vacumn which would cause the leaking. Another possible cause is vacumn leakage and you should check the hoses and their components. The manifold gasket and PCV are other areas to check.
Oct 17, 2008 at 2:11 PM
