Sometimes I am unable to put into gear, especially lower gears
2005 HONDA CRV
150,000 MILES • 2.2L • TURBO • 4WD • MANUAL
KO RA
Sometimes, gear would stick in and won't come out, only after a few clutch pedal presses. Master cylinder changed 2 years ago, slave cylinder checked, no damage or leakage. Also, when pressing clutch pedal slowly when idle, I can feel some clear vibration of the pedal around midway. What could be the problem? Thanks.
Nov 12, 2019 at 9:55 AM
Grinding and hard to engage/disengage gears are the two most common causes of a failing clutch and/or hydraulic system. When you add the chatter that you are feeling, I would just go ahead and replace the clutch and related components.
https://www.2carpros.com/articles/clutch-symptoms
Let me know if you have questions but you have quite a few symptoms of needing a clutch.
Nov 12, 2019 at 7:57 PM
KO RA
Many thanks. Will now go ahead and have it taken out to see if it needs replacing.
Nov 12, 2019 at 11:41 PM
Sounds great. Please come back if you need other things in the future. Thanks
Nov 13, 2019 at 7:08 PM
