That is reset when the oil is changed. Is the oil level full? Here are directions for checking. The attached pic correlates with the directions.
2019 Honda Truck CR-V 4WD L4-2.4L (K24V9)
Engine Oil Level Check (2.4 L Engine)
Vehicle Engine, Cooling and Exhaust Engine Engine Lubrication Engine Oil Service and Repair Procedures Engine Oil Level Check (2.4 L Engine)
ENGINE OIL LEVEL CHECK (2.4 L ENGINE)
Check
1. Engine Oil Level - Check
See pic 1
1) Park the vehicle on level ground, and start the engine. Hold the engine speed at 3,000 rpm with no load (in P or N) until the radiator fan comes on, then turn off the engine, and wait more than 3 minutes.
2) Remove the dipstick, and wipe off the dipstick, then reinstall the dipstick.
3) Remove the dipstick.
4) Check the engine oil level. It should be between the upper mark (A) and the lower mark (B).
5) If the engine oil level is near or below the lower mark check for oil leaks, and add the engine oil (CLICK HERE) to bring it to the upper mark.
Let me know. As far as it saying 100%, once the maintenance light is reset, that is what it will read regardless if the oil has been changed, so we just need to confirm.
Also, have you mentioned this to the dealership? The vehicle is under 100% warranty.
Sep 7, 2020 at 8:40 PM
