2005 Honda CRV Rubbing noise in slow speed tight turns
2005 HONDA CRV
93,000 MILES • 4 CYL • 4WD • AUTOMATIC
CASTLES
  • 4 POSTS
Our CR-V recently developed the problem above. The noise doesn't happen in reverse. It seems worse when turning right. I've ruled out a tire rubbing and the power steering pump. One wheel bearing was replaced: didn't help. I would appreciate any ideas. Thanks.
Jul 5, 2009 at 2:30 AM
KHLOW2008
  • 41,814 POSTS
Hi castles,
Thank you for the donation.
I believe the noise is emitted from the rear differentials and this is a common problem for CRV.
Replacing the rear differential fluids would solve the problem. Only the recommended Honda DPSF - II fluid should be used. Any other fluid would cause the grating noise.
Jul 5, 2009 at 6:14 AM
CASTLES
  • 4 POSTS
The noise seems to be coming from the front. I can also feel vibration in the steering wheel.
Jul 5, 2009 at 11:38 AM
KHLOW2008
  • 41,814 POSTS
The groaning noise would be transmitted to the front via the propeller shaft.
There was a TSB on the problem and maybe you could check with your local Honda dealer if it is a warranty problem.
If it is the front that is causing the nopise, you would need to check if the brake backing plate is too near the brake rotors. They would be brushing during turns causing the noise.
Jul 5, 2009 at 11:59 AM
CASTLES
  • 4 POSTS
I've looked for a TSB without success. Can you tell me which TSB you mean?
Jul 5, 2009 at 11:40 PM
KHLOW2008
  • 41,814 POSTS
Here are the TSB information.
https://www.2carpros.com/forum/automotive_pictures/192750_TSBRearDifferentialCRV01a_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_TSBRearDifferentialCRV01b_1.jpg
Jul 6, 2009 at 10:11 AM
CASTLES
  • 4 POSTS
Thanks a lot. I'll give it a try.
Jul 6, 2009 at 1:03 PM
KHLOW2008
  • 41,814 POSTS
You are welcomed and will be keeping my fingers crossed that it solves the problem.
Jul 7, 2009 at 1:30 PM
