2005 Honda CRV Honda special Transmission fluid
2005 HONDA CRV
73,000 MILES • 4 CYL • 2WD • AUTOMATIC
NANCYO
To save money I have been trying to do my tune ups as thrify as possible without skimping of course on necessary things.
Honda's owner manual really stresses the importance of using Honda oil, transmission fluid , and other needed fluids.
I called and talked to someone in the service dept. He said I could get away with using other brands with most with the exception of the transmission , he said he could almost promise me that my transmission would blow ( not sure of the exact words) if I did not use
Honda transmission fluid.
So,,,,,,,,,, how true is it of these car companies that INSIST that if you do not use Honda or Toyota fluids when replacing you will surely pay the consequences.
Just curious..
Thanks
Nancy
Nov 16, 2009 at 10:53 AM
SERVICE WRITER
  • 9,123 POSTS
Honda is one that is sensitive to using the right fluids and I stay with the honda fluids.
I would recommend that the differential fluid gets changed on this truck with the honda fluid as well. The little difference in cost is worth it on this one.
Nov 16, 2009 at 10:57 AM
