While on the driver side, if I go to push the window switch to go down on any of the windows it will not go down when it is hot outside. However, if it cools down outside the windows will go up and down freely. Recently I am unable to put down the back, right, rear window from the drivers side. However, anyone sitting on the right, back rear window can push the button up and down. Overall, if it is hot outside the windows will not go down from any switch. I checked all the fuses in the car and under the hood and I have not seen a problem. What could be the cause of this, is it a relay switch? or a short in a wire somewhere?
Aug 11, 2010 at 4:38 PM
