2004 Honda CRV noise or vibration while turning
2004 HONDA CRV
DLMCCLEAN
Noises problem
2004 Honda CRV 4 cyl All Wheel Drive Manual 80k miles
recently changed brakes on all 4 corners. Same weekend, took the vehicle to the snow for the first time, using the all wheel drive. Now, when I turn sharply either left or right, vehicle makes kind of grinding noise or vibration. Braking and everything else appears fine when driving straight, only sharp turns
May 6, 2008 at 10:58 AM
KHLOW2008
  • 41,814 POSTS
When was the last time you replaced the rear axle oil? This is a high pressure oil which have a life span of about 60,000 km (32,000 miles) and will cause vibrations when turning.
May 26, 2008 at 9:28 AM
