2003 Honda CRV Driver power window
2003 HONDA CRV
12,000 MILES • 4 CYL • AWD • AUTOMATIC
TRAXDOG
Stuck in the up position. No noise at all when I push the switch on the door. All other windows work fine
Jun 27, 2010 at 9:53 AM
CARADIODOC
  • 34,306 POSTS
Hi traxdog. Welcome to the forum. A common problem is broken or frayed wires between the door hinges but you can rule that out since the other windows work. The next most common possibilities are a defective motor, burned or pitted switch contact, or a cable that has become frayed or broken.
If the problem is with the cable or anything else that is causing the window to bind, a trick to prove the rest of the electrical circuit is ok is to watch the dome light when the engine is not running. If the circuitry is working, the light will dim a tiny little bit when you press the window switch. You have to look very closely to see the slight change in brightness. If there is no change in brightness, suspect the switch or motor. Voltage tests at the the motor's electrical connector will determine if the switch is at fault. Another trick is to switch the two wires to the motor to make it run in the opposite direction. If that makes the window move the other way, suspect the switch. Using a pair of clip leads to connect the wires to the motor is a lot easier and faster than physically pulling the wires out of the connector body and switching their locations.
caradiodoc
Jun 27, 2010 at 1:09 PM
TRAXDOG
I did as suggested to look for dimming of the dome light when I engaged the power window. It did dim the dome light. I am not sure what to do next.
Thanks
Jun 28, 2010 at 7:19 AM
CARADIODOC
  • 34,306 POSTS
Dandy. That tells you the motor is being energized. Next step would be to pull the door panel off to inspect the regulator. Expect to find a frayed cable or something else causing the window to bind.
caradiodoc
Jun 28, 2010 at 2:37 PM
