2003 Honda CRV deep rumbling when turning to the left
2003 HONDA CRV
TRAINER98
Noises problem
2003 Honda CRV 4 cyl All Wheel Drive 68900 miles
when I turn my car to the left,there is a deep rumbling/grating sound.just had repairs done that do not seem to have fixed the problem.tires were replaced,a leak in the struts was addressed and premium oil change was done using a thicker oil
Jan 13, 2010 at 3:58 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the doantion .. much appreciated Start by having the wheel/hub bearings checked for wear/damage ..
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_962.png
Jan 13, 2010 at 7:15 PM
The oil change, struts, and tires have nothing to do with a grinding noise when turning left. Does the sound go away when you drive straight? Were the brakes checked? Did they make sure the backing plate on the rear of the rotor isn't rusted or bent and hitting the rotor? Also, is it a clicking sound or truly a grinding? Did they check the CV joints and universal joints?
Jan 13, 2010 at 7:16 PM
Sorry, I wanted to add that I don't know what weight oil they put in the engine, but I strongly recommend staying within the manufacturer's recommendations based on temperature. Also, did they check the hub bearings?
Jan 13, 2010 at 7:17 PM
