Cruise control will not work. The light does not come on when cruise control is turned on and it will not engage cruise control.
Jul 26, 2010 at 1:20 PM
KHLOW2008
CERTIFIED EXPERT
Hi briant97,
Check fuse # 4 ( 10 A ) in under dash fuse/relay box first. If that is okay the problem usually is in the clock spring under the steering wheel but to be sure here is the wiring diagrams and a guide to help you test the system to confirm the failure;
