Cruise Control not working
2002 HONDA CRV
150,000 MILES • 4 CYL • AWD • AUTOMATIC
HELPMECRV
Hello all - I am hoping that somebody here can help me with this problem. Having some problems with the cruise control. After driving it for about 40-50 minutes, the cruise just cuts out. I can then reset the cruise and it will work for about another 20 minutes. When the cruise stops working, the cruise light on the dash stays on for about a minute and then goes out. After resetting the cruise, the light comes on back as normal.
I have replaced the Actuator and the Cruise control module, but neither have had any effect on the problem described.
Can someone please help me ????? This is driving me nuts !!!!
Mar 26, 2008 at 1:56 PM
XANDER777
  • 4 POSTS
[quote:a7b476f3ce="helpmeCRV"]Engine Performance problem
2002 Honda CRV 4 cyl All Wheel Drive Automatic 150000 miles
Hello all - I am hoping that somebody here can help me with this problem. I have a 2002 CR-V that is having some problems with the cruise control. After driving it for about 40-50 minutes, the cruise just cuts out. I can then reset the cruise and it will work for about another 20 minutes. When the cruise stops working, the cruise light on the dash stays on for about a minute and then goes out. After resetting the cruise, the light comes on back as normal.
Can someone please help me ????? This is driving me nuts !!!![/quote:a7b476f3ce]
I am having the exact same problem. Except sometimes the cruise will slow down, speed up, slow down and then shut off.
Have you figured out what the problem is?
Aug 26, 2008 at 2:51 PM
KHLOW2008
  • 41,814 POSTS
Hi xander777,
If the speedometer is not working correctly, it can cause the problem.
Aug 31, 2008 at 2:16 AM
XANDER777
  • 4 POSTS
[quote:a67c9bf139="KHLow2008"]Hi xander777,
If the speedometer is not working correctly, it can cause the problem.[/quote:a67c9bf139]
The speedometer is working fine. It almost seems like an overheating problem. The cruise must be on for at least 6 or 7 straight minutes before it happens.
If I tap the brake or press Cancel before that time, I never get the problem, only if its been on continuously. Once it shuts itself off, the problem happens again within a minute or 2 unless I turn off the master switch for sever minutes. Once I turn the switch and the Cruise back on, I may get another 6 or 7 minutes before the problem happens again.
On a side note, it hasn't happened as much lately since I've been using the AC less. Don't know if it's tied to AC usage or not.
Sep 2, 2008 at 7:15 AM
KHLOW2008
  • 41,814 POSTS
Hi xander777,
I would suspect a bad power source. Possibly the connectors are contaminated and causing high resistance which when heated up will fail.
Sep 2, 2008 at 8:13 AM
XANDER777
  • 4 POSTS
[quote:2aff36d048="KHLow2008"]Hi xander777,
I would suspect a bad power source. Possibly the connectors are contaminated and causing high resistance which when heated up will fail.[/quote:2aff36d048]
I'll check it out. Any idea where to look for the connectors?
Sep 2, 2008 at 8:54 AM
KHLOW2008
  • 41,814 POSTS
Hi xander777,
Try the control module and underdash fuse box.
Sep 2, 2008 at 12:30 PM
XANDER777
  • 4 POSTS
[quote:e1b167372e="KHLow2008"]Hi xander777,
Try the control module and underdash fuse box.[/quote:e1b167372e]
Sorry for the dumb question, but where's the control module?
Sep 2, 2008 at 1:01 PM
KHLOW2008
  • 41,814 POSTS
Hi xander777, It is the cruise control unit.
https://www.2carpros.com/forum/automotive_pictures/192750_CruiseComponentsCRV02_1.jpg
Check #10 (7.5A) and #4 (10A) in under dash fusebox and #7 (15A) in underhood fusebox. Check if horn is working. Check if the tachometer is working properly.
Sep 3, 2008 at 6:13 AM
69KADETT
2004 Honda CRV 4 cyl Two Wheel Drive Automatic
My '04 CRV w/ AT and 110k mi cruise control is doing the same thing. Has your cruise cuntrol problem been resolved?
Aug 4, 2009 at 11:06 AM
KHLOW2008
  • 41,814 POSTS
Hi 69kadett,
So far both have not replied back so I am not sure if they resolved the problem.
Aug 4, 2009 at 11:37 AM
JIMHO
CRV 2004 AWD/AT 160k
Any answers? Similar cruise control problem. KHLow2008--Is the cruise control unit the same as the cruise control module?
Sep 15, 2009 at 10:03 AM
KHLOW2008
  • 41,814 POSTS
Hi JimHO,
Yes, they are the same item.
Sep 15, 2009 at 10:16 AM
JIMHO
The original post of "helpmeCRV" on 3/26/08 says that he changed the "cruise control module".
My 2004 CRV cruise control will also work initially for 30 or 40 minutes, less on hills, and then sputter, slow down, and the cruise stops working, and dash light goes off. However, the main cruise control switch to the left of the steering wheel stays on. But it must be turned off and then on again to reactivate the cruise system. Cruise will only work 10 or so minutes when it fails again.
Any solutions anyone?
Sep 15, 2009 at 10:14 PM
KHLOW2008
  • 41,814 POSTS
Seems this poblem is not isolated.
Try this, when problem occurs, use your foot to pull the brake pedal up slightly and try resetting the cruise control to see if it works. If it works, the brake pedal switch is out of adjustment.
Sep 16, 2009 at 10:32 AM
PARKERB
I was able to resolve the same issue with my 2002 CR-V after performing a load test on the battery - it was only pumping out 7.5 volts.
Replacing the battery has solved the problem with the cruise control randomly cutting out.
I hope this is helpful.
Apr 7, 2010 at 9:01 AM
FLIVER
  • 9 POSTS
Ialso have 2002 crv with same cruise problem as .any others. I replaced the battery because it was bad. But it did not fix the cruise.
Fliver
Apr 12, 2013 at 5:35 PM
E8USAFNCO
problem solved! i replaced the switch cluster at the steering wheel from a wrecked cr-v. this is the 3 switch cluster used to "set", "cancel", and "accel" since then i've driven with the cruise on for at least 5 hours without incident.
Jul 5, 2016 at 5:58 AM
HENRY W WHITE
  • 6 POSTS
I have a 2002 CRV with same problem. Changed out the cruise control switch worked for 3 minutes then cut off. Battery is at 13.9v when driving. Should I change out the cruise control module next or try the brake pedal analysis first. By the way cleaned all the contacts already with electric contact cleaner.
May 7, 2019 at 8:17 AM
9 times out of 10 it is the clock spring which goes out due to wear. To be sure here is a guide to help you check the wiring and the cruise control wiring diagrams so you can see how the system works and the instructions on how to check the clock spring out in case it proves to be faulty:
May 7, 2019 at 2:52 PM
HENRY W WHITE
  • 6 POSTS
Thanks Ken. I think it might be the brake pedal switch. I will check on my way home today.
May 7, 2019 at 3:08 PM
Please let me know.
May 8, 2019 at 10:38 AM
HENRY W WHITE
  • 6 POSTS
Nope didn't work. cruise came on for about 1/4 mile then went off, would not stay on anymore.
May 8, 2019 at 11:27 AM
HENRY W WHITE
  • 6 POSTS
Next I'll change out the cruise control module.
May 8, 2019 at 11:28 AM
The brake light switch or the clock spring?
May 9, 2019 at 12:56 PM
HENRY W WHITE
  • 6 POSTS
Cruise control module.
May 9, 2019 at 1:49 PM
Sorry, which did you try the brake light switch or clock spring that didn't work?
May 10, 2019 at 10:10 AM
HENRY W WHITE
  • 6 POSTS
Switch on the steering wheel reset, cancel, set.
May 10, 2019 at 2:10 PM
The part I think is the problem is the clock spring. check out my earlier post. Let me know please.
May 13, 2019 at 12:28 PM
