2001 Honda CRV humming noise
2001 HONDA CRV
88,000 MILES • 4 CYL • 4WD • AUTOMATIC
JOANIE46
when I make tight turns, or a uturn, there is a loud humming noise, seems to be coming from the rear, but I'm not positive. Tires are new, bearings are fine, have had regular service since purchasing new.
Jun 19, 2008 at 9:56 PM
KHLOW2008
  • 41,814 POSTS
Hi joanie46,
I suspect it is the rear differential causing the problem. The oil is overdue for replacement or the wrong type had been used.
Replace the rear differential fluid. Use only Honda DPSP II.
You might need to replace the fluid twice, replace once, run vehicle and if noise still appears at a reduced level, replace it again.
Dual pump fluid Part # 08200-9002, 1.3 quarts
Jun 20, 2008 at 10:38 AM
