window not working?
2000 HONDA CRV
239,000 MILES • 4 CYL • AWD • AUTOMATIC
BMELSKI14
Ever since I had my lock assembly replaced , my window gets stuck. It will go down and back up only the first few inches and the last six inches... in the middle, it gets stuck and I have to push it down or pull it up. I tried dry Teflon spray and it helped a bit. Would another spray help (silicone)? Could it be the motor or the regulator?
Jun 5, 2008 at 7:39 PM
If this is not coincidence then you will need to remove the door panel and operate the window and see what it is binding on. Clearly a lock assembly should not effect this so we need to remove the panel and see what is happening. I suspect something was moved in the path of the window and it is getting hung up on it.
Here is a guide on how to remove the panel:
https://www.2carpros.com/articles/door-panel-removal
Then if we need to replace the regulator, here is a guide that will show how to do this as well:
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Dec 3, 2020 at 5:39 PM
