My Honda CR-V had a bad catalytic converter so I replaced it with a good after market brand for around $500. The check engine light came back on again with the following code P204 Something to do with improper flow thru the converter, I replaced the O2 sensor towards the back tail pipe end of the cat. converter. Still I get the check engine light. Does the computer have to be reset by a Honda tech to recognize the non factory catalytic converter. Is something else causing the code to go off? At my wits end! Any help would be greatly appreciated!
Thanks Doug
Thanks Doug
Feb 11, 2010 at 11:17 AM
