2000 Honda CRV 2000 Honda CRV Rear Brake Drum Adjustment
2000 HONDA CRV
107,000 MILES • 4 CYL • AWD • AUTOMATIC
DG4GA
Hello, after placing new drums and shoes on this 2000 Honda CRV LX what is the proper method for setting the correct adjustment so that it won't be to tight or too loose. The first thing I noticed is that the rubber boot on the back plate to spin the star for adjustment isn't compatible for using a regular flathead screwdriver because I tried seeing if it would help me setup so that I could get a slight drag but it needs to be a speacial bent tool the reach it.
Sep 17, 2009 at 9:18 PM
TED-E-DEE
  • 109 POSTS
The 1st thing you can try, providing the adjusters "Free". Find a large area where you can back up safely. With one foot on gas pedal, one on brake & approx. 5 - 10 m.p.h., apply brakes several times & the auto-adjusters should bring rear brakes up to proper adj.. The other way is to remove the drums & turn adj. wheel while putting drum on & off to check untill you feel a slight drag. {Very Slight} I do not beleive there is a tool to go through backing plate. I worked on Hondas for 16 years, I never heard of one & I never could find or make anything for going through backing plate. I take it adjusters are freed-up when you replaced brakes or you would have had trouble putting drums on. Good Luck !
Feb 25, 2021 at 10:24 AM
