The key is not turning in the ignition at all times. Problem seems to be getting progressively worse.
Jan 17, 2010 at 10:39 AM
KHLOW2008
CERTIFIED EXPERT
Hi Jim O'Brien,
The key cylinder is failing due to wear internally. Try some WD40 into the key slot to see if it helps. This is only a temporary fix and you would have to replace the key cylinder sooner or later.
