1999 Honda CRV Clock
1999 HONDA CRV
130,000 MILES • 4 CYL • AWD • AUTOMATIC
KARENSPICKLER
My Honda CRV clock stopped working. I paid for it to be fixed once before but I understand that is is fairly easy to do. Can you send me directions on how to fix it so that i can stop paying others to do it.
May 20, 2010 at 11:43 AM
F4I_GUY
  • 3,302 POSTS
Well it's hard for me to tell you what to fix when it could be a multitude of faults. The easiest thing to check would be your fuse. Check all your fuses in your fuse panel, one might be blown.
May 28, 2010 at 4:20 PM
JWPTREK
I've had the same problem with my 99 CR-V's clock. I took it out and opened its housing. Inside, you'll see parts on the board, including several resistors, which appear as flat components, about 1/4" x 1/8" that are black with numbers, like '103' or something like that. I forget the actual values. Anyway, you'll see that one or two have cracks in the solder. I just remelted the solder on one end, added some, let it cool, and repeated on the other end of each resistor. (I'm an electronics engineer so I solder all the time.) My clock has worked fine since. It's not dimming now, so I need to pull it and do the fix again. I'll add a post with a picture when I do so. I've done a similar fix in the compass module in a 2000 Mercury Mountaineer.
Jul 13, 2010 at 6:58 PM
