Shuts off while driving
1998 HONDA CRV
215,000 MILES • 4 CYL • 4WD • AUTOMATIC
AMANDUH_
My car has stalled on four separate occasions. Each time it has happened, I was able to pull over and put the car in park. Turn off the engine, wait for about a minute or two and turn it back on just fine. Below is a description of each occasion.
1. I drove less than a block from home and the dash lit up and the car was stalling (I am not sure what lit up exactly). I heard clicking noises from the dash (if my memory serves me correct, because everything happened so fast). I pulled off to the side of the street. Turned off the car, turned it back on with no issues and it drove just fine.
2. I drove for ~2 miles on the way home from work. I was taking a turn and noticed the car slowing down when I had my foot on the gas. This time all of the lights on the dash turned off and it was difficult to steer. I put the car in park and turned off the car. Turned it back on within 1-2 minutes no issues, again it drove just fine.
3. I drove for about 2 miles from a friend's house going home and the car started slowing down even with my foot on the gas pedal. I pulled off to the side and put the car in park. I haven't turned off the car yet. If I remember correctly the oil and battery light were on and I tried taking it out of park but it would not let me. I turned off the car and it turned on just fine and drove home.
4. Today, I was driving home from work. The car slowed down while my foot was on the gas. I looked down at the dash and the speedometer and tachometer were not working and all the lights on the dash were off. I immediately turned on my hazard lights and those were flashing on the dash. I pulled off to the side, wheel was hard to steer. I put the car in park, at this point I have not turned off the car yet. Before I reached to turn it off, the oil, battery and park light suddenly appeared. This time I was able to take it out of park despite having those lights on, but I put it back into park and turned off the car. Turned it back on and it drove just fine.
My dad has been trying to help me diagnose it, but he's also telling me to look on the internet for some solutions. I looked up the VIN on the internet and know that the ignition switch is a common issue. It looks like that was taken care of by the previous owner, because I did not see that recall come up. My dad is a DIY kind of guy and would rather solve this issue without taking it to a shop. I believe we have replaced the fuel pump, ignition coil and module so far.
Model: 4WD EX 4AT with 210,000 miles+
May 25, 2022 at 10:25 PM
There are a couple things we need to start with.
First, we need to scan for codes.
If there are no codes, then we are going to have to start with the basics.
First and foremost, we need to check the oil level and see if the oil level is low.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
If the oil is low, then we need to change the oil and find out if these issues continue.
If the engine oil is not low, then we need to run through this guide which covers the most likely causes of the engine stalling while driving.
https://www.2carpros.com/articles/engine-stalls
Please run through this info and let's get this info and go from there.
Thanks
May 26, 2022 at 2:50 PM
