1998 Honda CRV idle air control valve and motor problems
1998 HONDA CRV
94,000 MILES • 4 CYL • FWD • MANUAL
IHATECIVICS
i had the check engine light come on and it read the code for the iac vavle i took the old one off it looked dirty
i sprayed the throttle body and changed the valve and filled the coolant level wheree it need to be.
the light came back on after like 45 miles off driving i gueess its not the iac. do u know what the probelm is
my motor will not go past 5.5 rpms and it readlines at 7.5 i asked my other mechanic and its not the iac valve or the engine light pleaes help
Aug 18, 2008 at 11:01 PM
KHLOW2008
  • 41,814 POSTS
Hi ihatecivics,
If the scan after replacement of the IAC still shows IAC is faulty, you need to replace the PCM. When IAC falis due to shorting, the PCM would get damaged.
Aug 21, 2008 at 12:21 PM
