1998 Honda CRV hesitation when changing gear
1998 HONDA CRV
94,000 MILES • 6 CYL • 4WD • AUTOMATIC
MUSTY
My car always hesitate when shifting to the next gear. this mostly happens when I keep the car for like two or three house. It will jerk before changing the gear.
Aug 18, 2009 at 5:01 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Aug 18, 2009 at 5:13 AM
