If the clock no longer lights up but you can still see the numbers then yes the bulb is at fault. If you cannot see any numbers its more likely that you either have a blown fuse, bad wiring or the clock is stuffed. As for pulling the clock out, im sure on that model you have to start from the bottom and work your way up. Chances are if you havent done this before you will crack, or damage the plastic panels. There are alot of hidden screws as well as points where you should lever the panel to loosen the clips with out damaging the plastic covers. If you dont know what your doing and you dont want to make your interior look like crap, take it to a workshop. That way if they damage anything its there problem.
Dec 21, 2009 at 5:34 PM
