1997 Honda CRV Dim Headlights
1997 HONDA CRV
150,000 MILES • 4 CYL • 4WD • AUTOMATIC
D_TORRES2
My girlfriend's car has very faint head lights. The only way she can drive at night is with her high beams on which are only as bright as my regular low beams on my car. She has taken the car to several shops and they have told her it is fine or that the bulbs are misaligned. However, they have not fixed the problem. New bulbs do not work any better. so I am thinking it could be electrical. Any suggestions?
Dec 7, 2009 at 6:43 PM
KHLOW2008
  • 41,814 POSTS
Hi d_torres2,
If the lens of the headlampes looks yellowish, they would not provide bright headlights. There are polishes and treatments available for clearing the lenses.
Check the headlight focus, out of focus lights would not show well in dark areas.
Dec 8, 2009 at 8:43 AM
CYNDI LAURIE
Simple solution (for me at least)!
You described my problem exactly, but it turned out the low beams actually were on. Try rotating the lever just on more notch.
Apr 18, 2018 at 11:03 PM
STEVE W.
  • 15,116 POSTS
Common reasons for dim lights are, Failing alternator that isn't keeping the battery charged, Failing battery that is pulling the voltage down. Yellowed plastic that is blocking the light. Old bulbs, even the best bulbs will lose some lumens over time due to deposits building up inside the bulb case.
The biggest issue I see however is corrosion in the connections causing reduced voltage at the bulbs themselves. The corrosion acts as a resistance and instead of full battery voltage at the lights you get a reduced amount, even a 1/2 volt drop can cause a light to be noticeably dimmer. This voltage drop is why manufacturers started adding relays to the system. The relay allows for a shorter run from battery to lamp which reduces the voltage lost in the wiring and switches. For the cars with corrosion, cleaning the corrosion off the contacts and grounds combined with new bulbs and adding dielectric grease to the various connections to slow new corrosion can make a dramatic difference.
Apr 20, 2018 at 8:44 PM
