1997 Honda CRV Battery Light is on
1997 HONDA CRV
172,000 MILES • 4 CYL • AWD • AUTOMATIC
LAWOFFICEMOUSE
I have a battery light on in my CR V. I see one belt in the engine. It is to the right as you look under the hood. It is working fine. Is there another belt that may have broken and causing the battery not to charge? Or is this simply an matter of needing a new battery? I did find that the battery cells were in need of fluid.
Thank you.
Sep 17, 2008 at 8:16 AM
KHLOW2008
  • 41,814 POSTS
Hi lawofficemouse,
The charging system is faulty and you need to check the alternator, its belt and fuses.
Battery condition is a different problem.
Sep 26, 2008 at 10:29 AM
