water in gas tank
HONDA CIVIC
RAMSEY2007
Just been driving for about 40 miles with my gas tank cap and gas tank door open after filling tank. It's been pouring with rain for the entire trip. The door was ajar slightly. My petrol gauge has used about what it would for that distance, and the car hasn't stalled or "jerked". I have driven for another 40 miles after closing everything. It's my understanding that the water would have settled at the bottom by now and I would have felt a "jerk" or the car would have just switched off if there was significant water in the system. I would appreciate some input in this.
I drive a 2006 honda civic sedan EX.
Tom
Apr 15, 2007 at 2:23 PM
CARBOY
  • 14 POSTS
You probably did not pick up too much rain. What water you did get will settle to the bottom of the tank where the fuel pump will pick it up and send it up the line to the fuel filter element which can hold a certain amount of water. That is part of its job. I would have the filter changed. You could add a bottle of "gas dryer" to the fuel tank before that. It is an alcohol which will mix with the water droplets and help transport them out. When I change out fuel filters on cars I always dump the contents out and frequently see rust, dirt, and water.
Apr 17, 2007 at 8:15 PM
PCHOMINSKI
  • 17 POSTS
Do not worry, this is not dangerous, unless water will freeze in the pipes from the tank to the engine. Then you will have to be tow to the warme area.
At the end of 60-ties we performed experiments with injecting watter into the carburators in order to decrease combution temperature and increase efficiency. Experiments indicates also that NOx emission was lowered. Those experiments leaded to invention of EGR.
Few engine design centers around the world had prototypes with additional water injection, but it was not convenient for every day car user. It has to be distilated water in order to avoid stone building. This would be a problems in the area where tempretaure goes below freezing point.
In order to lean up your tank, you can poor about 1 liter of denaturated alcohol per 20 liters gas (5% max) into the tank aybe twice and then replace fuel filter.
May 11, 2007 at 1:04 PM
