Honda Civic engine knock when idling and A/C on
HONDA CIVIC
JNOWICZEWSKI
2000 Honda Civic VP, 137K miles, 1.6L 4-cyl
I am having an issue with my Honda Civic. When the A/C is on and the car is idle, the engine starts to knock and it seems like the A/C is cycling on and off.
When the car starts moving, the A/C works fine. The issue is only when the car is idle.
I added some 1394 freon thinking that it was low, but that did not help.
Any thoughts of what might be causing the engine knocking?
Oct 4, 2007 at 4:15 PM
BRUCE HUNT
  • 3,754 POSTS
First of all you need to ask if it is the engine or a component on the engine. For instance, the compressor itself can knock and the power steering unit can knock as well. Another possibility is a motor mount. You need to do some deeper investigating.
Oct 5, 2007 at 11:12 AM
