engine knock, noise
HONDA CIVIC
FRANCANO
I have a 2001 honda civic, model HX. It has a manual 5 speed transmission, with 170k miles. The timing belt was replaced at approximately 160k miles. About 3-4 weeks after the belt replacement, the engine started to make a knock, pinging noise. The noise only occurs at 2500 rpm in 4th or 5th gear. Usually any rpm or speed less or greater the noise goes away. Any suggestions? Thanks for your help.
Aug 11, 2007 at 9:42 PM
2CARPRO JACK
  • 11,533 POSTS
Have you used any fuel additives? ran fine for the first few weeks.... maybe a tank of bad gas? any check engine light? any other performance problems?
Aug 12, 2007 at 8:57 AM
