I’m from Pakistan and own a 1994 Honda Civic EX 1.5 with 5 speed M/T and carburetor (chassis code: PK4). The car has done 174,000 km and has been regularly serviced. Recently I have noticed that the car starts emitting black smoke and soot from the tail pipe after a while of idling. If left unchecked, the engine becomes rough, the rpm starts falling and the motor finally dies. However, if I rev up, the engine picks up after emitting a moderate amount of black smoke from the tail pipe and runs fine at all higher speeds (no smoke, no loss of power). Let me also mention that I have a slight leak in the cooling system (probably in the gasket) and will soon be taking the car in for necessary repairs. In the meantime I regularly check the coolant level and top up if required. What is my problem at idling? Could it be related to the cooling system leak? Any help will be appreciated.
Regards,
Dr. Tariq Hakim
Regards,
Dr. Tariq Hakim
Jan 19, 2006 at 9:39 PM
