95 honda civic 1.5 motor tranny over drive sticking
1995 HONDA CIVIC
HONDAGUY2008
I have a 95 honda civic with an 1.5 motor and Automatic Transmission with 100,000 miles on it.. when you start it up for the first time of the day and back it out of my drive way get going about 65mph stick it in cruise control and the over drive will not shift in overdrive for about quarter mile or little more down the road.. Other than that one time it works like it should what could be causing this or how expensive is it to repair? thanks
Nov 12, 2007 at 10:17 PM
Might want to have the throttle position and vehicle speed sensors check before you think shifting solenoids and the TCM.
When was the last time this transmission seen a transmission service? An engine performance problem will cause the tranny not to operate properly.
Major Tune-up and fine adjustment.
Need repair manual see below link
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 14, 2007 at 4:14 PM
HONDAGUY2008
[quote:a817614cd5="rasmataz"]Might want to have the throttle position and vehicle speed sensors check before you think shifting solenoids and the TCM.
https://www.2carpros.com/kpages/auto_repair_manuals.htm[/quote:a817614cd5]
When i bought the car i did a tune up on it spark plugs, airfilter, oil change oil filter, about month ago it started acting up which within 3 or 4 days after i got an appointment to have the fluids changed in tranny and was told that some 1 put an additive in it cause fluid came out orange it hasn't cleared up or anything, all gears kinda shift ruffly
Nov 14, 2007 at 4:45 PM
