Engine Coolant Leak?
2006 HONDA CIVIC
80,000 MILES • 4 CYL • FWD • AUTOMATIC
REDNUROIT
Have a 2006 Honda Civic. 80,000 miles. Kept good service on it since new. Never had a problem until today. The car has developed a coolant leak and I am having a hard time finding the source of the leak. All of the hoses seem intact and dry. The water pump looks good and dry too. The thermostat area seems dry also. I can smell coolant and see it dripping on the ground after I shut off the motor.
Under the hood I do notice a wet area on the motor and it is definitely coolant but I can't find the source. I can see coolant on the motor just to the right of the exhaust pipe (viewed from under the hood. Please help ! and thank you in advance. John
Nov 7, 2009 at 3:36 PM
RAMIREZ0478
I'm having the same issue with my 2006 Civic. I had no idea that it was leaking coolant until my car started overheating. I could just smell the antifreeze when getting out of the car. Very frustrating and hoping its not an expensive issue. check out this guide
https://www.2carpros.com/articles/car-is-leaking-coolant
and
https://www.2carpros.com/articles/coolant-leak-symptoms
Nov 8, 2009 at 9:25 AM
REDNUROIT
Took the car to the dealer and to my very surprise it turns out that Honda has an engineering/manufacturing/ production flaw with the engine blocks actually CRACKING !! CRACKED ENGINE BLOCK ! Can you believe it ?
And I am sorry to say that Honda will not cover it. Shame on you Honda !
This is NOT an isolated incident. These engine blocks are cracking in many, many of these cars.
Nov 9, 2009 at 2:44 PM
HONDACOOLANTLEAK
  • 4 POSTS
[quote:d96e893066="rednuroit"]Took the car to the dealer and to my very surprise it turns out that Honda has an engineering/manufacturing/ production flaw with the engine blocks actually CRACKING !! CRACKED ENGINE BLOCK ! Can you believe it ?
This is NOT an isolated incident. These engine blocks are cracking in many, many of these cars.[/quote:d96e893066]
I had the same problem, cracked engine block. Honda covered it under warranty as it is a lease. I just got the car back today, drove to work, and upon checking on my car around lunch time, all the coolant has leaked! It is still a problem! You are not alone, I am very displeased with Honda. I called the Honda Dealer Repair Shop and they asked me to bring it back. C'mon ALREADY!!!
Don't know what the issue will be this time. i was without the car for 6 days! Now I have to take it back...
Nov 11, 2009 at 11:04 AM
HONDACOOLANTLEAK
  • 4 POSTS
[quote:bca907e76b="ramirez0478"]I'm having the same issue with my 2006 Civic. I had no idea that it was leaking coolant until my car started overheating. I could just smell the antifreeze when getting out of the car. Very frustrating and hoping its not an expensive issue.[/quote:bca907e76b]
I had the same problem, however the Honda repair technicians said it is becuase of a cracked engine block. Honda covered it under warranty as it is a lease. I just got the car back today, drove to work, and upon checking on my car around lunch time, all the coolant has leaked! It is still a problem! You are not alone, I am very displeased with Honda. I called the Honda Dealer Repair Shop and they asked me to bring it back. C'mon ALREADY!!!
Don't know what the issue will be this time. I was without the car for 6 days! Now I have to take it back...
Nov 11, 2009 at 11:05 AM
HONDACOOLANTLEAK
  • 4 POSTS
[quote:48a77a49be="rednuroit"]Engine Cooling problem
2006 Honda Civic 4 cyl Front Wheel Drive Automatic 80000 miles
Under the hood I do notice a wet area on the motor and it is definitely coolant but I can't find the source. I can see coolant on the motor just to the right of the exhaust pipe (viewed from under the hood. Please help ! and thank you in advance. John[/quote:48a77a49be]
Don't know what the issue will be this time. I was without the car for 6 days and have to bring my 2008 Civic back... So frustrated...
Nov 11, 2009 at 11:07 AM
