2006 Honda Civic 2006 Honda Civic
2006 HONDA CIVIC
110,000 MILES • 4 CYL • FWD • MANUAL
DAVID.ROYNELLE.KEOLA
  • 16 POSTS
I was trying to take down the oil pan, which was replaced before, and I noticed that the bracket that connects the ac compressor is attached to the oil pan, so I knew that I would have to take out the bolts on the bottom. the problem is, the bolt head is rounded. Its in a tight area, so I cant saw off the bolt head, or use vise grips, or anything. How can I get this bolt out, or atleast get the head off. And its a really off size bolt head. 15/32. Everything was millimeters. 10-14 mm. What do I do? I have to get these bolts off, or i cannot take out the oil pan. any suggestions?
Sep 30, 2010 at 1:56 PM
F4I_GUY
  • 3,302 POSTS
If you can put a wrench on it, you can put visegrips on it. Try using vise grips. If the head is badly rounded, you might have to use a chisel and a hammer to loosen it, then once it's loose use pliers to un-loosen it.
Sep 30, 2010 at 5:32 PM
