coolant reservoir overflowing
2005 HONDA CIVIC
75,000 MILES • 4 CYL • FWD • AUTOMATIC
GHEAMAIR
The coolant is overflowing and spraying from the two small holes under the coolant reservoir cap - only during extended highway driving. I am unable to create the leak with routine short trips, extended periods of idle, etc. Once the car is parked and allowed to cool overnight, the reservoir level never quite returns to "max" - it remains elevated instead of being pulled back into the radiator. The car hasn't overheated, and the needle never rises above the halfway point. Could this be air in the system. Is there anything that would prevent return of coolant to the radiator after the engine cools. I replaced the radiator cap first - no change. I rented a leak tester and combined that with UV dye and was unable to create leaks anywhere. No oil/coolant contamination visible. No performance problems. No overheat. Any suggestions or advice would be greatly appreciated.
Thanks, Scott
Jun 14, 2010 at 3:57 PM
FRENCHYAZ
It's all come down to suction.Have you tried to drink your glass of water with a defective straw? you can if you work hard on it but if the straw works 100% it'll be much easier and with less effort.
Unfortunately your radiator cap is set to constant pressure of 1.1 atmosphere and cannot overcome the loss of pressure like you would do while drinking with a straw.
Coolant going to the overfill tank uses gravity and pressure built up from the radiator however the radiator needs to work against gravity in order to bring back the coolant inside the radiator.
I got a similar issue with my 2001 Civic (187,000 miles) and my overfill tank was way over the max line I set it up while my radiator was getting empty.
A lot of people don't diagnostic correctly and don't go over the cap swap and if it didn't work, well too bad, you have to change your head gasket (very expensive). Your description of the problem doesn't make me lean toward a head gasket issue but know that I could be wrong.
I fixed my issue for just about $5 dollars. When I emptied the overfill reservoir in a clean bucket (water jug), I've noticed some black specks in it, which made me think that some rubber is deteriorating (AKA hoses).
On my Civic, I have 2 hoses joined with a plastic coupler. One side goes from the radiator to the coupler, the other side goes from the coupler to the reservoir tank nipple.
I decided that the lower hose was potentially the issue and decided to swap it (I'm cheap even though the hose, 5/8th ID was only $2.19). I also got some worm type clamp (don't use zip ties) and put them strategically.
I put a clamp where the hose connects to the overfill tank nipple, 2 on the coupler on both sides where the hose meet the coupler.
I filled up the overfill tank to the MAX line, made sure the radiator was full and went for a ride.
After 20 min driving I opened the hood and as expected the coolant was about 1/4 inch above the MAX line (coolant expanded in the radiator and it went to the overfill tank). I let the car sit overnight and in the morning I checked it again. The coolant was back to the Max line, meaning the system works as expected again.
Bottom line, don't always believe what you read on the Internet and stay logical, sometime the solution is as simple as it sounds.
Sorry for the long thread, hope it'll work out for you the same it did for me saving you money on the way.
Enjoy!
May 31, 2016 at 11:14 AM
EBZB12000
I had a overheating problem and noticed that:
1. coolant was flowing out from reservoir.
2. coolant not topped off in radiator.
3. steam or white smoke from tailpipe
I topped off coolant after engine cooled down and removed air bubbles. I proceeded to drivea nd after a while, the temp went upagain. So, I turned on the heater and temp went down while driving.
I noticed that I still have:
1. power
2. fuel mileage still good
3. no smell of coolant from exhaust or interior
The next day I checked for signs of a blown Head Gasket and Radiator leak by checking for:
1. white smoke from exhaust (tailpipe)
2. milky residue in dipstick and under oil cap when
engine was cold
3. discoloration of spark plugs
4. discoloration of coolant
5. leaks around engine and connecting hoses
6. spills under car
7. radiator fan turning
8. both radiator hoses had the air sucked out
(imploded)
I then replaced the coolant, thermostat & radiator cap
All I have now is:
1. steam or white smoke from exhaust (tailpipe)
when idling (even after engine is warm,but
disappears after I drive it around)
2. coolant fills up when idling,but overflows from
reservoir only while driving
Also, my engine doesn't overheat anymore.
Please help!!!!
Aug 10, 2019 at 4:02 PM (Merged)
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you is your Civic a DX, EX, GX, HX, or LX Coupe or Sedan. Also you engine size in liter
EBZB12000
I have a 1.7 L, fwd, at 2001 honda civic ex sedan
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the detailed info…………….
Do you have heat for the inside of the vehicle…..are both heater hoses hot going into the firewall?
What it sounds like is a blown head gasket….if you have white smoke out the tail pipe.
You may see traces of oil in the coolant………
What may be going on is when you are at idle….it is leaking enough into the cylinders to burn out the tail (the white smoke) which is why the coolant reservoir doesn’t’ fill.
You start driving…more pressure so the exhaust from the cylinder is now blowing into the coolant…..thus the tank overflows and or bubbles……….
I have never used this before and you could check with your local auto parts store to see if they have something similar….but here is a web site that you can get this leak kit and if it changes color…then you know you have a blown head gasket.
I do think with the white smoke though…..head gasket.
JEANNIE8
  • 8 POSTS
Today my 97 Honda Civic overheated. The radiator was cold. This radiator is only a year old. Why is this happening and what to do?
Car temperature was in the red zone. Smoke was coming out from under the hood. Coolant was dripping all over though the coolant reservoir was full. Checked hoses, saw nothing loose or cracked. Radiator was cold to the touch.
I just had this radiator replaced only about a year ago.
TWO LANE
  • EXPERT
  • 34 POSTS
Sounds like the coolant is not flowing, check the thermostat and check the water pump if the rad was clogged half would be hot and the other cold.Did you do anthything to the system like flush you can try that just make sure you get all the air out.
Thank you
Two Lane
KHLOW2008
  • 41,814 POSTS
When engine is cold, remove the radiator cap and check the coolant level.
The cold radiator indicates there is no coolant inside the radiator.
VIPER007OC
Just a couple months ago, I noticed a strange white foam puddle forming under my '98 Honda Civic EX coupe. I checked under the hood to find foam bubbling out of the reservoir cap. While driving, no indicator lights are showing, and temperature reads normal. I have to constantly add distilled water to the reservoir. At the same time, the car seems to be either burning or losing a lot of oil. After 3 months from changing, less than 1 quart remains in the engine. Engine smells bad after just a few minutes of use. Could these be related or completely separate issue? How to fix?
Aug 10, 2019 at 4:03 PM (Merged)
CARADIODOC
  • 34,306 POSTS
Sounds like you're describing one of the ways a cylinder head gasket can leak. Your mechanic can perform a chemical test at the radiator to confirm that. The test involves drawing air from the radiator through a glass cylinder with two chambers partially-filled with a special dark blue liquid while the engine is running. If combustion gases are present, the liquid will turn bright yellow.
CJ MEDEVAC
  • 11,004 POSTS
it's possible that you overheated the engine and now have a head gasket issue
mr. owner's manual, in most every vehicle, from the beginning of time, prescribes checking your oil level and coolant level, at minimum......weekly
running your engine for, however long, below the safe mark, may have caused internal engine damage
the medic
VIPER007OC
Thank you for your prompt response! I will attempt your ideas immediately.
AJW2286
I recently flushed my coolant system and have been driving my car for about a week but today it decided to leak coolant to the point of overheating. When I opened the hood it looked like it was leaking out of the coolant reservoir or the reservoirs lid. It was also spewing white smoke out of the exhaust. Does the reservoir need to be replaced? Did the lid just come loose? Would this cause my problem?
LEGITIMATE007
  • 5,121 POSTS
either of those could be the problem, cap or resevoir, try tightening it first(of course) then check the res. for any cracks or cracks in the hose coming off of the radiator to the res. the white smoke scares me, I really hope the head gasket wasnt compromised. when it overheated
