2002 Honda Civic radiator fan not running
2002 HONDA CIVIC
89,000 MILES • 4 CYL • FWD • AUTOMATIC
AUTOQUESTION
The radiator fan is not runnning, and the water temperature gauge on the dash gauges is running a bit higher than normal. Does this sound like the fan thermal switch should be replaced, or would this be a thermostat replacement issue (or both)? Thank you for your help.
PS. Not sure if this is related, however I had driven through some deep water (flooded road) prior to this happending, and I imagine that some of the fan wiring got wet.
Jan 2, 2008 at 10:02 PM
Water is a conductor in electricity theory-maybe why its not coming On because the fan motor is shorted out. Try running it direct to the battery and see what happens.
Or a problem with the temperature switch and the fan relay.
Jan 3, 2008 at 3:21 AM
