2002 Honda Civic P0300, P0301, P0302, P0303, P0304
2002 HONDA CIVIC
106,000 MILES • 4 CYL • 2WD • AUTOMATIC
SUZBANDIT987
  • 14 POSTS
I am getting these 4 errors. I've checked the coil pack, and wires going to the coil packs. Everything looks ok. I got 12.4V with the key on, at the connectors going to the coil packs. I got 48.5-50.2 Ohms off the coils packs.
Now I would like to check the Camshaft Sensor, and Crankshaft Sensor. Where can I probe these sensors and what volatage, or resistance should I expect to see from these sensors.
FYI, I have an ODBC program I used to scan the car's PC, and I am only getting the 4 DTC's I listed in the Subject line.
***Edit***
I found a wiring diagram. This diagram said the CKP Sensor should be: Signal Wire-Blue, Ground-Brwn/Ylw, and Power (12V)-Ylw/Blck
I found a Blue wire with a single gray (paint) dot every inch or so. I probed it. It read: 1.36Kohm key off and .26V key on.
The diagram said the TDC Sensor should be: Signal Wire-Green, Ground-Brwn/Ylw, and Power (12V)-Ylw/Blck
I found a light colored solid green wire. I probed it. It read: 3.6Kohm key off and .325V key on.
I found a darker colored green wire with a single gray (paint) dot every inch or so. I probed it. It read: 0.5ohm key off and .01V key on.
The diagram said the IAC Valve should be: Signal Wire-Black/Red, Ground-Black, and Power (12V)-Ylw/Blck
I found a black/red wire. I probed it. It read: 1.17Kohm key off and .5V key on.
Almost all of the power wires in this harness are Yellow/Black. I found one of these and probed it. It read: 12V Key On.
Also I went back to basics and took out and read all 4 spark plugs. I'm assuming #1 is the right-most cylinder when facing the engine. Plug #1 had a tan strap otherwise was mostly black. Plug #2 was 100% black. Plug #3 had a tan strap otherwise was mostly black. Plug #4 had a tan strap otherwise was mostly black. Most of the plugs were darker than I would expect, but it's all relative to the way the car has been running, I'm sure.
Mar 13, 2010 at 2:09 PM
SUZBANDIT987
  • 14 POSTS
Anyone, please. Help needed.
Mar 13, 2010 at 11:50 PM
KHLOW2008
  • 41,814 POSTS
Hi suzbandit987,
Thank you for the donation and sorry for the delay in replying.
From the symptom and condition description of the spark plugs, I believe they are bad.
The spark plugs are shorted causing the misfiring. Get them replaced and retest.
Even if the spark plugs are new, I would not discount the possibility of them going bad.
Was any repairs done prior to this occurring?
Mar 14, 2010 at 1:00 AM
SUZBANDIT987
  • 14 POSTS
The 100K maintenance was complete about 3 months ago. Timing belt, Water Pump, Tensioner. I changed the spark plugs about 8 months ago, or so. At this point I was assuming the plugs looked the way they did because my wife ran the car in this misfiring condition for several miles. I will of course take your advice and we'll see what happens.
Mar 14, 2010 at 1:22 AM
SUZBANDIT987
  • 14 POSTS
Why do you say that you believe the plugs are shorting?
*Edit*
So I assume you do not see anything wrong with the electrical measurements I took...right?
Mar 14, 2010 at 1:23 AM
KHLOW2008
  • 41,814 POSTS
No, the readings do look ok. When a problem occurs, we need to start with the basics to avoid unnecessary and expensive parts and time to be wasted.
If problem had started after the timing belt replacment, then you could have a timing belt synchronisation problem. Recheck the timing belt markings to ensure they are correct.
Mar 14, 2010 at 1:42 AM
SUZBANDIT987
  • 14 POSTS
Ok, I changed the spark plugs. When I started the car it acted the same. Very rough idle, and acted like a car that is running a cylinder or two short. Also the car will not rev above ~3K RPM. What's next? The only thing I haven't checked is the fuel injectors....
Mar 14, 2010 at 11:31 AM
KHLOW2008
  • 41,814 POSTS
The trouble codes you posted on the title had been truncated due to space. Can you please list them all out for me so I know I jhave not missed anything.
When was the last time you retrieved the trouble codes?
Are they still the same? If yes, I would suggest getting a compression test done first.
As the spark plugs are sooty, the injectors should be working.
It definitelty seems like you have a cylinder that is not firing well.
Try to identify which cylinder is acting weird by disconnecting the injector connector one at a time to test.
Get a compression test done to see if the readings are within specs.
Mar 14, 2010 at 3:44 PM
SUZBANDIT987
  • 14 POSTS
The codes are P0300, P0301, P0302, P0303, and P0304.
Mar 14, 2010 at 8:05 PM
SUZBANDIT987
  • 14 POSTS
I ran a compression check. #1 was 235psi, #2 was 235psi, #3 was 230psi, and #4 was 235psi.
What are the odds of having good compression on all cylinders if the timing belt skipped a tooth or two?
The new spark plugs I put in this morning already look terrible, with #3 still looking the worst. Doesn't that make sense with the timing belt theory?
Mar 14, 2010 at 9:54 PM
SUZBANDIT987
  • 14 POSTS
I went to scan for codes again, but my laptop died. I'll re-run a new scan tomorrow and post up what I find.
Mar 14, 2010 at 11:16 PM
KHLOW2008
  • 41,814 POSTS
Th trouble codes indicate a misfiring in all the cylinders. Here is a chart for the misfiring and what to check for.
https://www.2carpros.com/forum/automotive_pictures/192750_DTCP0300_02CivicFig75_1.jpg
The compression is rather high, specification minimum is only 153 psi. Timing belt off a cog might not affect the compression much but it will affect the ignition timing. Get a timing light to check the ignition timing and if it is out of specs, that would confirm the timing belt installation error. If above all looks good, check the fuel pressure. The fuel injectors could be possible causes too but it is not likely for all 4 to go out at the same time. Another thing to check would be the valve clearances. I have sent the complete diagnostic procedures to you as pdf files. It is too large to be posted here. Let me know if it gets through correctly.
Mar 15, 2010 at 6:59 AM
SUZBANDIT987
  • 14 POSTS
Why would compression be too high? Let me double check and make sure I didn't read KiloPascals and report in PSI.
My car is more the misfiring at low rpm's and under load type.
I did not get the files you sent me.
Mar 15, 2010 at 9:30 AM
KHLOW2008
  • 41,814 POSTS
I am resending the file.
Mar 15, 2010 at 10:34 AM
SUZBANDIT987
  • 14 POSTS
I still have not recieved the PDF you sent me. I will run another scan in a couple of hours and see what codes I have now.
Mar 15, 2010 at 12:22 PM
KHLOW2008
  • 41,814 POSTS
Ok, in the meantime we shall also wait and see if the files arrive.
Mar 15, 2010 at 12:26 PM
SUZBANDIT987
  • 14 POSTS
Still no PDF. I scan the car again, and now I get NO codes what so ever?? I ran it, rev'ed it, scanned it. No codes. Reapeat , still no codes.
Mar 15, 2010 at 4:25 PM
KHLOW2008
  • 41,814 POSTS
Do you have any other emails that I can send the files to?
Misfiring codes sometimes requires repeated occurrence so you might need to drive the vehicle for a longer period.
Do you have difficulty starting after engine is stopped for some time? At least the starting time is prolonged whereby you need to crank for some time?
Mar 16, 2010 at 12:16 PM
SUZBANDIT987
  • 14 POSTS
I had a leak down test done at a local shop. They said the #2 and #3 are leaking badly (80%.) Does it make sense to have poor leak results but real high compression? Maybe if the timing were off??
These are my 3 options, right?
Timing Issue
Head Gasket
Bent Valve, Valve not Seating
How can I differentiate between these 3 issues. I'm thinking to check the timing indicators between the block and pulleys, check the oil and collant, but what about the valves? I suppose the only way is to disassemble until I can see them? Any other possible issues?
Mar 16, 2010 at 1:51 PM
SUZBANDIT987
  • 14 POSTS
The #2 and #3 exhaust leaks are leaks into the exhaust ports. Perhaps a valve spring broke or it ran too hot for too long. Is it acceptable to resurface the mating surface of the head, being that is it Alum?
Mar 16, 2010 at 6:27 PM
KHLOW2008
  • 41,814 POSTS
If the valves are leaking badly, the compression should be affected.
To confirm if it is the valves, loosen the valve lifters and with piston at BDC, apply regulated compressed air into the plug hole and listen for leaks at the exhaust or intake manifold.
The head or gasket would seldom cause any problem unless you have overheating and coolant losses issues.
I would suggest rechecking the timing belt installation first before you go further. A wrongly installed timing belt cvan cause leakages problem. If you have not checked the ignition timing, get ti done to see if it is within spec. An out of spec ignition timing would indicate an error with the timing belt installation.
Though the cylinder head is aluminium, it can be refaced but there is a limit to how much can be done.
Mar 17, 2010 at 7:02 AM
SUZBANDIT987
  • 14 POSTS
If the timing was off wouldn't I see all cylinders leaking? Not just the middle two.
Mar 17, 2010 at 3:51 PM
KHLOW2008
  • 41,814 POSTS
If the timing is off, you would normally have low compression all across but I am not sure how the leak down test was done so there could be some error while perfoming it.
Checking the timing belt is the easiest and fastest way to avoid expensive and time consuming repairs so why don't you perform it first?
While you are at it, with the pistons NOT at TDC and the valves free, tap the valves to let them seat correctly, sometimes dislodged carbon can cause leaks as the valve are not able to be seated fully.
If the timing belt installation is correct and you still have leaks at the valves, then a valve job would have to be performed as you mentioned checking the valve clearances and cnfirmed them to be correct.
Mar 19, 2010 at 11:44 AM
