Headlight ('01-03 models)
Disconnect the 3P connector (A) from the headlight.
Fig. 24: Disconnecting The 3P Connector From The Headlight (Headlight (High/Low): 60/55 W)
Courtesy of AMERICAN HONDA MOTOR CO., INC.
Remove the rubber cover (B).
Pull the retaining spring (C) away from the bulb (D), then remove the bulb.
Install a new bulb in the reverse order of removal. Make sure the tabs on the bulb align with the notches in the headlight.
Front Turn Signal/Side Marker Lights/Parking Light ('01-03 model)
Remove the inner fender .
Disconnect the connectors (A) from the lights.
Fig. 25: Disconnecting Connectors From Lights (Front Turn Signal/Side Marker Lights: 21/5W Parking Light: 5 W)
Turn the bulb socket (B) 45 ° counterclockwise to remove them from the headlight housing.
Install the new bulb(s) in the reverse order of removal.
Mar 6, 2021 at 5:21 PM
