Headlight bulb replacement?
2001 HONDA CIVIC
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
JAKE MASTERS
How are the front bulbs changed out?
Nov 23, 2008 at 4:37 PM
DAVE H
  • 13,384 POSTS
Headlight ('01-03 models) Disconnect the 3P connector (A) from the headlight. Fig. 24: Disconnecting The 3P Connector From The Headlight (Headlight (High/Low): 60/55 W) Courtesy of AMERICAN HONDA MOTOR CO., INC. Remove the rubber cover (B). Pull the retaining spring (C) away from the bulb (D), then remove the bulb. Install a new bulb in the reverse order of removal. Make sure the tabs on the bulb align with the notches in the headlight.
https://www.2carpros.com/forum/automotive_pictures/266999_light_1.jpg
Front Turn Signal/Side Marker Lights/Parking Light ('01-03 model) Remove the inner fender . Disconnect the connectors (A) from the lights. Fig. 25: Disconnecting Connectors From Lights (Front Turn Signal/Side Marker Lights: 21/5W Parking Light: 5 W) Courtesy of AMERICAN HONDA MOTOR CO., INC. Turn the bulb socket (B) 45 ° counterclockwise to remove them from the headlight housing. Install the new bulb(s) in the reverse order of removal.
Mar 6, 2021 at 5:21 PM
